how much drop with 15x8 rallies
ONEARMEDBANDITT
ga
matt
1500 choo choo customs
I have a 1987 custom deluxe pick up, it has 15x8 rallies on it with 275/60/15 I was wondering how much I could lower it without any issues.. I don't want to cut or grind on anything. thanks in advance
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
3 inches...using drop coils .....or 2-1/2 with spindles up front. Out back drop hangers.
animal
Lee
c10 silverado
350ish
Hangers will get you 2 inches. Add shakles and you get 4 inches. You might have to trim a bed support with both. @JKnight or @smoothandlow84 could answer for sure on that.
RThiel
Worland, WY
Robb
6.0 LQ9
2.5" spindles and 1" springs up front and a 5" flip in the rear (no notch needed, but need to remove rear bump stops) will sit you low and level without any major modification. Stock shocks on the front and mid 90's Nissan Hardbody shocks on the rear (I use cheap monroes vs. expensive drop shocks) and you're there.
smoothandlow84
Steve
Rear drop hangers...about 2...to 2-1/2". You might have to notch the bed frame supports depending on the hangers. My support rails are notched, however I also have a axle flip along with rear hangers which gave me a total of 7 inches of drop. I went a little further and removed my overload leaf spring to soften the ride...and now its currently closer to a 9 inch drop out back. I dont have 15" wheels, but 20" front and back. If you want to lower a bit, and not cut.....go with springs and hangers. (And get an alignment).
rickybobby69
