How does guage cluster ground?
Dyl0116
ONTARIO
Dyllenn
Just working on the guage cluster. nothing but issues. I was riding the other day and without headlight switch all guage lights came on. Right signal comes on when left signal applied. when right signal applied gas guage bounces. Gas gauge isnt working.. etc. What grounds the guage cluster.. anyone have schematics
Dyl0116
ONTARIO
Dyllenn
ok so update.. When checking guage cluster for power.. i pulled all guages out. The back lights were so dim! I inturn used a test light and as soon as I touched power ... the light got brighter. But the bulb itself seems to be kinda loose. I then used a multimeter and it has 7.4 volts continuous..
robert8096
Goose Creek SC
Robert
Most of the time there is a grounding block located right above the emergency brake assembly. Remove the cluster and look to your left. You should have a wire coming out of the cluster harness to ground. Here is what I got for cluster wiring.
-1 LT GREEN (HI BEAM)
-2 GRAY (ILLUMINATION)
-3 BLACK (GROUND)
-4 PINK/BLACK
-5 PINK/BLACK (IGNITION)
-6 ***BLANK SPOT IN CLUSTER***
-7 PINK (FUEL)
-8 DARK GREEN (TEMP)
-9 BLACK (GROUND)
-10 LIGHT BLUE (LEFT)
-11 DARK BLUE (RIGHT)
-12 PINK (IGNITION)
-13 TAN/WHITE (BRAKE)
-14
-15
-16
-17
-18 ***BLANK SPOT IN CLUSTER***
GM
CKT...DESCRIPTION.........WIRE COLOR
8......Cluster Lamps.........GRAY
11.....High Beam Lamp.....LIGHT BLUE
14.....Left Turn..............LIGHT BLUE
15.....Right Turn.............DARK BLUE
25.....Gen Telltale...........BROWN
30.....Fuel Gauge............PINK
31.....Oil Sender.............TAN
33.....Brake Lamp...........TAN/WHITE
35.....Temp Sender.........DK GRN
39.....Ignition Power.......PINK/BLACK
150...Grounds................BLACK
237...Seat Belt Warning...PINK/WHITE
931...Electric Choke........DARK BLUE
939...IGN Generator........ORANGE (idiot light clusters only)
DucatiDave
