How do you assemble the parts in the steering wheel for the horn button
73c20jim
Tombstone, AZ
Search shows thread with all pictures deleted.
1973 c20 ps stock wheel
service manual useless
Use this as a general guideline for GM steering columns . . .
  • Illustrated tilt steering column disassembly.doc
73c20jim
Tombstone, AZ
Thanks for your reply. I have steering column assembled.
I need to assemble the steering wheel horn assembly.
Do you have the type with the collar that's held down with 3 screws?
73c20jim
Tombstone, AZ
yes, plastic ring,
Ok, the little coil spring goes into the cancel cam first, then the little metal peg and then the little retaining collar. The collar rotates and locks into place. When installed properly, the metal peg should be kinda spring loaded.
Then the flat spring disc gets laid into place. Without having it in front of me, I can't remember which way faces up. I think the concave side faces you though. Then the steel cup goes on, followed by the insulating ring, then finally the three screws that hold it all together.
The horn cap pops into the steel cup.
73c20jim
Tombstone, AZ
Thanks. These are the parts I have. The little white thing has an extension completely around it. There is no tab sticking out to lock into cancel cam. I have no clue what the big white thing is.
I have no idea what the big white thing is either.
I'm gonna say that the little white piece is wrong for the application. Your cancel cam has the little hook notch in it, doesn't it?
73c20jim
Tombstone, AZ
Cancel cam is OK. Looking at the picture you see the little white thing has the circular ridge. It sits nice on top of the cancel cam.
I can cut the circle off and leave a tab. Don't know if it will strong enough.
On the happy side. I drove the trick out of the "garage" and around the block. Parked it and went inside. Rained. Since I don't have a window, the seat is now the largest sponge in AZ.
Lots of little things to finish besides the horn. I can always yell out the window because there is no driver's window.
Based on what I could find online, the 67-72 horn kits include that extra white ring, but its not part of the 73+ horn kits. I didn't think GM made any big changes over the years, but maybe that ring was needed only in the earlier columns.
73c20jim
Tombstone, AZ
Great info. Kit was probably designer for multiple years. OR I got the wrong kit.
73c20jim
Tombstone, AZ
I got the 1972 kit. Explains why it don't fit and has big white ring.
1973 up is different.
I also need a horn button. Mine is missing two tabs.
All I need in the picture above is the little white round thing that has a little knob and not a circle extension .
I should have an extra of the little white piece, I'll look in the AM.
73c20jim
Tombstone, AZ
It's not the one pictured, but one with a lille knob to hook into cancelling cam and retain spring.
Thanks again.
Do you also have a horn button with all the retaining arms???
clean 87
