How do i get to these c clips!?!?!
Subourbon
Quebec
K20 suburban
6.2 V8
Ove followed tutorials and i get the theory but this spring pack is kinda blocking access to get to these clips to pull the axles out.
Help pls! I've got all the parts and tools and everything I'm stuck here now
Subourbon
Quebec
K20 suburban
6.2 V8
It does. I freaked out lol
However. I pulled out a "repair bearing" i think.
Is that what needs to go back in? Coz im fairly sure I bought a standard bearing.
Subourbon
Quebec
K20 suburban
6.2 V8
This is what I pulled out
legopnuematic
Licensed Junk Dealer
MO
Spencer
Yes that is a repair type bearing/axle saver.
WFO
Texas Panhandle
Your axle/axles are probably worn.
If so, you need to replace the axle/axles, or find new axle saver bearings.
I went through this on my 69 Chevelle SS 12 bolt, and went ahead and bought new axles.
Subourbon
Quebec
K20 suburban
6.2 V8
I luckily found a place that has em. Sorta wholesaler that supplies auto part retailers. Theure awesome. I ask napa and they're like oh maybe tomorrow. Called these guys and they're like, yep it'll be here in 30mins from our warehouse.
Love em.
Now I need to install them without scrapping the seal. I looked quickly there isn't a specialty tool for repair bearings... none that I can see anyway. So will have to go gently
Carb'ed Vortec 350
I'd recommend replacing the seals. If you don't, good chance you'll be going back in to replace them due to leak(s) that developed
Subourbon
Quebec
K20 suburban
6.2 V8
The repair bearings come with a seal already installed. Bearing, outer seal inner seal all in one part.
The outer bearing cage (or outer race could be mixing up my terminology) sticks out just proud of the seal face. So really gotta watch it when installing..n now it's snowing..so I might wait a bit till it clear up... snow in November. Geez.
Subourbon
Quebec
K20 suburban
6.2 V8
Bearings are in the freezer, I do this at work, sometimes the smallet change in temp helps. One or two hits of a mallet and clunk. In she goes.
I've got some blue Gatorade colored grease on the bearing rollers. I'm assuming it's compatible with diff oil?
WFO
Texas Panhandle
Make sure those bearings are greased well. Those inner seals keep the gear lube from getting to them.
WFO
Texas Panhandle
Good deal
I was typing while you were posting.
Subourbon
Quebec
K20 suburban
6.2 V8
@WFO
yessir, theyre greased real nicely too.
When I was learning how to do this job, dude just dropped his OEM bearing into a Lil Tupperware of different oil. And never bothered packing them.
I'll be honest, the bearing install is making my palms sweat. The seal face is super close to the metal surface. Lol
Can I heat up the outside of where the bearings sits, obviously not inside, but jist around right behind the backing plate?
  • Like
Reactions: WFO
WFO
Texas Panhandle
@WFO
I've never put them in, just taken them out, so I'm not sure. Maybe a heat gun would help.
A big ass socket or a square cut piece of pipe should make a good driver though.
that_orange_c10
