That’s cool! Does you like how the aluminum rad and electric fans work?
Asking because I’ve thought about it if the radiators go out on either of the squares.
I absoultely luv this rad/fan set up. Painless make a great wiring harness for ele fan setup.
The two row alum v/s the stock single copper/brass is hands down more effecient.
I can grab the lower rad hose when I can't touch the top hose.
You can search the swap post on here.
The twin fans are shrouded pullers and I can feel air drafting 6" from the grill.
This rad is a direct fit. No mods needed.
Research aside, I've watched a number of speed/performance episodes and not one favors a copper/brass/plastic rad over aluminum. I suspect they might know a bit more than I.
The only guys doing original factory rads are guys being judged for factory stock competitions.
I prefer reliability.
But, to each his own.
