Hole Lotta Shakkin goin on
roy c
long island
roy
on a 93 K2500 sub any input on what causes the front to dashboard to fell like its going to shake out the window replaced inner outer tie rods, front
rotors pads calipers front hoses. could it be possible front anti-lock is going
bad some times it kicks in when it (I feel shouldn't) I'm pressing the brake
hard but not skidding. rear shoes and drums are new also and the the smaller shoe is toward the front of vehicle ball joints are tite as well as the upper and lower bushings any thing I've missed thanks roy
animal
Lee
c10 silverado
350ish
With all of the new parts I am guessing that you have tried swapping tires front to back to make sure its not an unbalanced wheel or some other tire issue??
Its doing this all the time or comes and goes? only at a certain speed?
roy c
long island
roy
all the time I changed the rotors and pads No change
I'm getting 4 new Michelins in the morning see after that
I have a feeling it something to do with the anti lock brake
system those speed censors on the front spindles are effecting
this
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
This might be stupid but im not familiar with ifs are your rotors held on from behind the hubs or do they slide on over it. I had same problem and i had rotors turned on the hubs to make them true and it worked out well took the wobble out of it. And thats after replacing all the parts to.
