hits hard going in reverse
prattville al
nathan
hey guys i have noticed when i shift into into reverse it takes a few times for to actually shift into the gear and when it does it hits kinda hard. and when im driving while its shifting it hits too. im thinking maybe a good flush and fluid and filter change might help. what do yall think?
Green79Scottsdale
G.R. - MI
Bob
What transmission do you have?
TH400 does this also, so I will be interested what others say. Mine is like a hard clunk, and it only does it going back into reverse, not to the forward gears.
prattville al
nathan
i think its a th400 im not sure and i cant find any numbers due to 30+ years of stuff build up and i ran out of brake cleaner -_- the transmission pan is square
chengny
im thinking maybe a good flush and fluid and filter change might help.what do yall think?
I think it couldn't hurt.
GM A/T pan ID chart:
prattville al
nathan
Weird thing is I have to sit there for a minute goin between park and reverse before it actually does anything
prattville al
nathan
it goes into all gears just not reverse or i have to shift from park to reverse a hundred times and then in finally shifts and jolts back like when you shift in drive and jolts forward. should i just get a rebuild kit by the way i found out its a th350 transmission.
Konas new ride
Alberta
Gerald
Have you just let the truck idle to warm up the trans to see what it does then?
prattville al
nathan
i have. even did a transmission flush with trans tune. put new fluid and filter in. and still had to go back in forth between park and reverse for it to shift.
Stewzer55
Ohio
Stew
R30
Does it have a shift kit installed? Hard shifts are not necessarily bad because they help with wear on the clutches.
prattville al
nathan
Not my knowledge. Honestly I might take it off and take to a transmission shop. I want a shift kit for it. I just want everything done right. It's my first project I don't wanna mess it up
Stewzer55
Ohio
Stew
R30
Wait until HRPC chimes in, he is our resident Automagic Trans guy.
prattville al
nathan
Ok will do. Hopefully he can save me from a headache and spending lots of money
sammygunns
