Dutch Rutter
- Aug 13, 2013
- Independence, Or
- Joshua
- K20
I said the magic words out loud the other day. "Truck is running GREAT!"
So naturally, this week I've noticed the idle in drive and with a warm engine is about 300-400 RPM higher then normal. Before I had it at 600-700, now its around 900-1000.
Normally, I would be thinking a small Vacuum leak somewhere, which I have not ruled out yet.
But could this also be a symptom of bad gas or a sticky choke?
Last tank of gas I had put into it was non-ethanol premium from a small local gas station. That was about two weeks ago. Now I'm less then 1/2 tank. I highly doubt they use too much of that in ground tank.
Or is there a way I can check to make sure the choke is fully disengaging?
Carburetor is a Edelbrock 1405 with the electric choke added to it.
Or should I just replacing vacuum lines?
Thanks!
Thanks!
