Help!!!!
Luis of EP
El Paso
Luis
r-20
Hi guys
I just started my 1987 V-10 finally and when we decided to take it for a spin, we put the truck in reverse and it died and then we heard a loud noise, we then pushed it back a bit and tried again same thing the engine stalls and we hear a very funny noise. We then got the truck out to see if drive worked and it did for about a mile we decided to see if we could then put it in reverse and the truck died again when we put it in drive again the Noise was louder and shook the truck and we couldn't move after getting the truck home we put the truck in reverse we noticed that the drive shaft is spinning and the tires don't move
So my question is what can i do to fix this problem?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Sounds like the crosspin retaining bolt may have backed out, letting the x-pin slip out a little and a spider gear jumped out of place. Hopefully your ring & pinion didn't get destroyed.
Luis of EP
El Paso
Luis
r-20
I'm going to be looking at it in the morning hopefully its nothing to big
Doh!
Luis of EP
El Paso
Luis
r-20
This is the results only pic i could upload
crazy4offroad
K-10
350/SM465/NP205
Exploded spider. Examine the other gears (other spider, both side gears, and main ring & pinion) and determine further damage. Small chips are ok but if you see a good chunk off a gear, and can tell it has seen drive force on it, replace what needs it.
Luis of EP
El Paso
Luis
r-20
All the internals in the truck are fried opened up the rear diff and found lots of pieces of gears... sad part is that i went to salvage yards and no one carries the gears i want/need they only sell the whole diff with unknown gears.... Anyone know where i can get all the internals for cheap or cheaper then most places?
Luis of EP
El Paso
Luis
r-20
The pinion on the truck is done for to couldn't upload the pictures of the other pieces that didn't make it
crazy4offroad
K-10
350/SM465/NP205
What's the specs? 10 bolt, 14-bolt semi-floater, 14-bolt full-floater? What gear ratio?
Luis of EP
El Paso
Luis
r-20
GM 10 bolt with 3.73 I'm really looking for 4.10s due to the large tires that the truck has.
Luis of EP
El Paso
Luis
r-20
If i can find or get pointed to a pair of 4.10s it would be heavenly
crazy4offroad
K-10
350/SM465/NP205
How big a tire you talkin? Time to upgrade to heavier axles? Otherwise keep breakin the 10-bolt ****.
Luis of EP
El Paso
Luis
r-20
35 in tires. Only thing holding me back is that this truck might be sold or parted out still don't know
crazy4offroad
K-10
350/SM465/NP205
Well hell I wouldnt bother with changing to 4.10s then.
Luis of EP
El Paso
Luis
r-20
Then do you know where i can find some 3.73 all salvage yards here don't sell just the internals must buy whole diff and the u-pull its don't have the right gears
What other vehicle can i pull the gears out off?
tman894
