Help
Boltrunner
Odin mn
Shane
V20
Im sitting here stuck at a rest area near home. I filled up about 20 miles ago and am empty again. I just put some fuel in and after i moved kept the truck idling. I watched the fuel start dripping out of my passenger side tank. I dont use that tank because i haven't replaced it yet. Any ideas?
K201979
Winona, missouri
Hippie
350ci
I dont know anything about the selector valve, but id try to find out how to bypass it. Sorry im not more help
75Monza
Colville, Washington
K30, K20, K20
On my 86, selector valve is up tight right about the back of the cab off passenger side frame rail, not exactly easy to get anything off it. If you have one good tank and a bad tank leaking your fuel out, switch is stuck in the middle or something...junk most likely. If you can get the bolts out and drop the switch, need to identify the hose going to the engine and the hose from your good tank and connect together with a barbed nipple or an old piece of metal fuel line and hose clamps so you are just using the one tank and bad tank is out of the picture.
Boltrunner
Odin mn
Shane
V20
Sounds good. Truck is on a trailer now headed to the shop where i have a skidder available to pull the bed and get a bettee look at it all. Odd thing is though is that it sounds like the good tank is priming into itself. Almost like something caused enough pressure to pop the pump off the sending unit.
Boltrunner
Odin mn
Shane
V20
The feed line is 3/8 correct?
75Monza
K30, K20, K20
Oh crap, forgot the 87 has in tank electric pump. Might be the short little rubber hose on the pump outlet, ethanol does wonders to old rubber fuel line.
  • Like
Reactions: WFO
Boltrunner
Odin mn
Shane
V20
I just bypassed the tank switch for now. New tanks are comming this summer anyway.
Scrambler-Cafe
