help
juanichi214
dallas
juan
r10
My turn signal fuse keeps blowing out
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Check your wiring for a short, check the bulb sockets for corrosion.
87silveradok20
Ohio
Levi
Silverado k20
and make sure that it has the right size fuse (not one too small). You can always put a bigger in.
juanichi214
dallas
juan
r10
I already put a 20 fuse they seem to work fine when I drop the gear to reverse and swap out the fuse but once I put the truck on park it blows it out again. Tried it multiple time same result
marks86
Latham, NY
Mark
12v Cummins
check ALL the lighting wires for loose/broken
How are your backup lights functioning?
firebane
Calgary, AB
Curtis
99% of the time the reason fuses pop is because of a short somewhere. This includes deterioated wiring, broken wiring, bad sockets somewhere or a wire broken.
Basic wiring 101 and these trucks are super simple.
datto62073
Monroe
Mark
mine did that. short in the reverse lights.
504SquareBody
