Help! Fuel tank delete?
gogo14910
Joe
350 SBC
87 Silverado: my pass fuel tank is never used. Yesterday it overflowed out of the filler hose while parked on a slope to pass side. I dropped the tank today and it was full of varnishy fuel. I cut the 3 hoses to the pump on that side. How can I just delete the tank? Fuel is dripping from big hose so I plugged it with a screw. When I crank the truck fuel is flowing from a smaller hose. How can I button this up? Thanks.
Scott91370
Burleson, Tx
Scott
Sierra1500
You can remove the entire switching assembly by connecting the 3 hoses that go from the switch to the engine compartment to the three corosponding hoses that go to the tank you want to keep.
gogo14910
Joe
350 SBC
How do I cut and connect the 3 steel hoses on the crossmember coming from the tank, to the hoses going to the engine?
Scott91370
Burleson, Tx
Scott
Sierra1500
I would leave the steel lines and just add a length of rubber fuel line from them to the corrosponding hoseon the other side of the switching mechanism.
Since you have steel lines, if you ID your lines that are good, and you also ID what goes to the front, if you have short distance between them if you were to use a tubing cutter as close to the hose ends or whatever as possible, like, no more than a few feet(generous) then use fuel injection hose and fuel injection clamps. They are SAE-J30R9 for the hose (J30R10 for inside the fuel tank) and
this is what the clamps look like, its sold at the store as fuel injection clamp
Im
not sure if the lines can be done without a barb or not(flare) but If they are like this at all, where they would push into eachother, then you can safely not use one. but something like a long 90 degree bend should not be done like this (Since it would pop off or tend to kink, if you get the meaning)
85K304SPD
Las Cruces, NM
Richard
You better drain out that gas from the tank. You are going through alot of unnecessary work to mess up your truck. Why not just fix it correctly? What is even the problem with the tank, or the switch?
gogo14910
Joe
350 SBC
The passenger, internal, electric fuel pump hadn’t worked since i got the truck. Never used that side but apparently the return kept going there. The fuel was varnish by the time it filled up(years) and it began to overflow. I didnt know it wold do that.
gogo14910
Joe
350 SBC
Im
Thank you, perfect!
85K304SPD
Las Cruces, NM
Richard
Just fix it, instead of messing up your truck. Much more of a long term solution.
gogo14910
Joe
350 SBC
If I delete the tank switching valve, will the fuel pump still have its own power? Or is that power delivered thru the adaptor plugged into the valve assembly?
Scott91370
Burleson, Tx
Scott
Sierra1500
That I do not know. My fuel pump is mechanical on the side of the block.
Your fuel pump connectors seal is sticking out of it.. i bet that thing is not working right because the pins are not all mating or corroded,. can you pull the valve and connector down and clean that up?
i cant see the locking tab but its also possible its connected backwards as well on the electrical connector.
it looks like the tank is selected by the 12 motor moving to which ever directed side, then the thing also swaps which gauge is on the dash, then the fuel is pushed by pump because it also flops the power for which pump is on.
gogo14910
Joe
350 SBC
Thanks for your help. I didnt know how to read all that but ultimately removed the tank selector valve and bypassed to only have my driver side tank connected. The internal fuel pump must have its own power source because It is running fine. Thank you for the diagram. I knew exactly which wires to cut and connect to make my fuel gauge work in the truck. I was the driver sending unit (pink/white) wire and the gauge wire (pink). Since they were all black from the years, they were wire 2 and 3. Everything is going well so far!
