Hello from Pennsylvania
:welcome:
WFO
Texas Panhandle
R10ish
Levittown
thank you for the hospitality, i am an 45 min north of philly. the swap i am doing is a complete swap from a fuel oil service van ( 94chevy g30) so the 350 tbi and 4l80e, harness, computer, and associated electronics. i have installed a tilt column and buckets seats. and its up and running. i will post pics soon. sorry for the delayed response, i work nights and have been grinding away on this thing to get this baby on the road
R10ish
Levittown
welcome also from PA doing a swap from a 700r4 (ripped apart the sun gear assembly) to a sm465 208 combo good luck on your swap but if you do drop in a 350with a 80e you should get the motor and trans as one unit from the same vehicle with the wiring harness it will make it MUCH easier most stand alone shift controllers are not cheap by any means and dont get me wrong i like carb but efi is an easier start in the winter time and doesnt have the ethanol issues a carb does i had a holly street demon on a 351 in an old 72f100 i had and it would cause scaling in the carb
the other toy is a 2001 blazer with an lt1, its TPI and its super fun but was a PITA to wire up, including 2 computers. so this one is a simpler project, or a gift if you will as the wiring is FAR less complicated
78C10BigTen
pennsylvannia
C10 BIG TEN
Not all that far from me
R10ish
Levittown
R10ish
Levittown
This is the front end idea I landed on, wife does vinyl, and I had the old school hella fog lights that were the exact size as the old turn signals
alysco
