Hello and help please
sig79
benton, arkansas
ray
Unfortunately, I can’t read the numbers on the old one…
Is that a single element bulb? Normally a bulb with 2 contacts on the base has 2 elements. Look in the lamp socket itself see if it has 2 contacts in other or 1 contact.
Old Guy Bill
KY
Bill
It’s a two contact bulb, my ‘78 has the same dome light.
LMC has the regular or the LED bulb..
Jgonick
West Texas
Joel
bulb 1004
attachment shows bulbs for 79
Jgonick
West Texas
Joel
pics it looks like an 1142 bulb.
Both have a BA15D (double contact bayonet) base. 1004 and 1142 are interchangeable most of the time. 1142 would be brighter, but higher heat output (could potentially damage fixtures). 1142 was used in the cargo light.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Interesting that a single filament bulb uses a double-contact base. If they make an LED replacement I'd go with it.
My 1989 had different types. I switched them all (dome and reading lights in overhead) for LEDs because one was burned out and when I went to replace it, the plastic housing was slightly deformed and blackened. Looked like a fire tried to start. LED heat output is so much less. Plus I can leave them on as long as I need and not even notice the battery drain.
Chevy 88
Canada
f7t6
GMC
I had a dome light bulb issue once on an older rig.
This was the solution:
Marine Corps Moderator
:welcome:
sig79
benton, arkansas
ray
Thanks to everyone for all the help and support…found these on Amazon and they seem to work fine for dome and cargo …
Nardulli
St Louis
C15
Welcome from St. Louis
Nborden88
