Heater fan
Copymutt
Colorado
Already scrolled thru 20+ discussions and no mention of this.
74 K20, heater control worked as its designed-low medium high speed fan.
In the process of painting firewall I see the 3 wire connection at the fan box has a low resistance coil of wire between 2 leads. There’s also a cut wire going to the third terminal. What’s up w/ that? Must be factory for different set up?
FenderBanger
