Headliner Trims
Doppleganger
OH-MI: Just like it sounds
How many pieces are there of the interior trims? My truck has nothing inside but I'm going full Silverado on it.
2 A-pillar trims, 2 B-pillar, front-back-both sides of the headliner (4 pcs), 2 down low (vent areas).....any more?
Thx.
Ellie Niner
Tucson, AZ
Tory
K10 Silverado
LE9 305
There are 2 more short pieces that join the A-pillar trim to the kick panel trim; they're sort of pinched between the dash pad and the door weatherstripping.
The 4 straight pieces that go above the doors, windshield, and back window are painted metal, and the rest are plastic. The kick panel pieces have a totally different "grain" pattern than the rest of the trim on mine.
Scott91370
Burleson, Tx
Scott
Sierra1500
Between the two of you that's all of them. The small sections that go between the dash and cab aren't that noticable though.
FireTruck1984
Michigan
Ted
1984 and 1984
Thx.
Be sure to get the correct color-ColorBond paint and spray all parts to uniform color/shade. It makes a noticeable difference!
SquareRoot
@Doppleganger
You doing this or what? I have been contemplating it myself. Looking at LMC, it looks like the ABS Headliner comes as a kit and includes all the the trim panels:
"Headliner Kits are designed for models not originally equipped with a factory headliner. Separate panels to cover the side pillars below the headliner are included. (Drilling into the inner roof panel is required.)".
I'm not sure if that includes ALL the trim pieces (the front/back & Side pieces). If so, $ 259 for the kit is not bad IMO.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
@Doppleganger
NOOOO!
The “Kit” includes two long stick on Velcro strips to attach it to the roof, and cardboard pieces of trim for the pillars. The trim is just covered with some cheesy fabric.
I already made that mistake myself. It would be better than nothing I guess. But the money saved on the other one can be put towards the legitimate plastic and metal trim parts.
SquareRoot
NOOOO!
Good to know. My truck never came with one. I prefer the metal and/or plastic trim pieces. Besides the abs headliner what is available? Are the replacements just like the OEM fiberboard?
CalSgt
CA
Casey
Not sure, all the stuff I saw marketed was ABS.
I kept the headliner from the kit and ordered all of the trim and screws. I think it was Classic Ind or USA 1 that had all the trim in stock. It was an expensive purchase
SquareRoot
Thanks for chiming in on the thread. I appreciate the info and alerting us to another rabbit hole waiting to devour our pride and credit cards!
CalSgt
CA
Casey
Here it is without the windshield trim installed. I had the ABS one covered in grey tweed to match my seats. The grey cloth on it really clashed with my interior fabrics, amazing how many different shades of grey there are.
Doppleganger
I didn't get the kit as everyone was out of stock on one piece or another. I wound up getting a close 'dark gray' covered headliner with the intent of spray dying it to match the charcoal dash, etc. I also collected all the plastic parts (LMC iirc - took awhile with backorders) and then the side pieces in OE metal from the yard. They are all generic black that I'll also paint to match the charcoal interior.
Going to mock everything up in my stripped cab, so I can predrill the holes before the whole thing gets painted.
I tried in vain to buy it all in color from USA1 - but backordered items I canceled 2 yrs ago are STILL out of stock. UFB.
Shawn Watson
New Mexico
Let us know how the mock-up/pre-drill idea goes. I'm also doing a Silverado trim into a Scottsdale upgrade so I don't have any holes to work with and was wondering the best way to go about it.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
What Brand/color of paint are you using to match the color? I asked USA-1 when I got some sun visors a few years ago, but they just told me it was a general color they used- no help...
On my last truck, '79 K15, I found a bunch of parts on line, circa 2013. From the factory, it did not have a headliner so I had to drill all the holes. I swapped over to the 81+ interior. I did a quick clean up with TSP then just sprayed Dupli-color vinyl paint. Black on the dash and dark gray on everything else.
On my '85 I did not have the rear cab light, but I added this factory switch then added LED light inside my truck box and on the bed facing side. You do have to drill a hole in the B pillar for the switch to fit.
1979 K15
1985 Cab switch
Hard
