Headlights quit working
dc1974
saskatchewan canada
Dave
silverado big 10
383 stroker
Question maybe someone can help me out…
I had my front end all apart when I pulled my motor, had most of it sandblasted and powder coated.
After replacing the motor and putting it all back together all my lights worked my problem is signal lights work fine with no other lights on. When you pull the park lights on the blink a little slower and if you pull the headlights on they quit all together.
WTH is going on…
Thanks for any help
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Three words --- grounds, grounds, grounds... Each and every place where the ground wires attach, you MUST grind off the powder coating down to bright bare metal.. Apply a thin layer of grease on the contact area and put a star washer between the wire terminal and the contact surface..
midwest
Indiana
Scott
I don't know much about wiring and vehicles but the one thing I have learned over the years of owning a square body is that most of these issues are ground related. My tail and break lights both stopped working last year. Upon pulling the lenses one of the ground wires was broke and it was fixed easily.
CheemsK1500
K1500
In the case of pre-1984 squares, I have found a faulty floor-mounted high/low beam switch to often be the cause of sudden headlight failure or inconsistently functioning headlights. If it is not that, it is either going to be ground issue, or a continuity issue.
GTX63
Tennessee
Ty
Has anyone mentioned grounds yet?
Using a test light, follow your ground wire from the lights, (both headlight and signal) back. I'm pretty sure you will find the issue under the hood.
If you powder coated the motor, run an external ground from the back of your alternator to the frame. There is an unused bolt back there just for that.
Those old AC Delcos are grounded to the block from the factory via the bracket and powder coats are a ground killers for alternators.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I second this. Was cruising home one night, pitch black country road, and hit the dimmer because of an oncoming car and bam, no lights. Stomped the switch a couple times until I got high beams back and then drove home. I would definitely check the dimmer switch first.
dc1974
saskatchewan canada
Dave
silverado big 10
383 stroker
Thanks, I’ll see what I can find
Dejure
Eastern Washington
Kelly
C15
Working a "the headlights just quit working" issue. JUST AFTER cleaning up battery connectors. That was the first place I looked. No satisfaction there.
The headlamp bulb checked good.
Pulled the switch and checked for voltage. Nadda.
Went to the [floor] dimmer and pulled it. A minor amount of corrosion on the input terminal, but, generally, looked okay. Got twelve on the connector input terminal.
Head scratch.
Pulled the jewelers files, cleaned the contacts, then pushed silicone grease into the connectors. Plugged it back on the dimmer and pulled the switch again and I had lights.
It appears the minor amount of corrosion was enough to kill the circuit. Just unplugging the dimmer and plugging it back in might have brought life back. At least temporarily.
In the end, it's not just about grounds. Dirty contacts can issue-matic too.
Years back, I had an issue on my 71 Chev. Checked a fuse for the involved circuit. The fuse showed good, but touching the holders would have suggested bad. Had to fire up a Dremel with a stone about the size of the curve of the holders to clean them all up. Greased them and put the fuses back and all was well and fine again.
NOW I have to see why the battery drained, AND why turning on the headlamps causes the left indictor to come on, steady, and both turns to stop.
DID NOTE around 3-1/2 ohms to body ground, Should be near zero, according to diagrams.
Maybe Detroit's better ideas weren't.
bigrich
