GMC-IH
dragstews
GMC-IH
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
Jumping Jack Flash !
Finding a adapter was a major chore ...
Had to be able to work the telescopic lever ...
Found one that had the right dimensions for the Raptor's bolt pattern ...
Getting a few bucks wrapped up in this tricked out column ...
Close to 9 C-notes so far .. Eek
If my labor was $100 a hour ... Aaaaaa, I don't want to think about it !
Be here Monday ...
Found two other adapters that are for telescopic columns ,,
They was two piece designed ... I liked this one cause it was a solid piece ...
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Since the old Binder had seen some fat added to the body thought was to fatten up the steering wheel ..
Keeping the dark walnut look ...
I do like the wood and black leather wheel, but this one has "Beef" written all over it ..
Well ... Since I was undecided on which steering wheel to get I consulted the "Magic 8 Ball", it said the Wood & Leather wheel ... So be it !
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Got a idea on how to go about hiding the one inch gap ..
Do a counter bore down into the adapter with a slight press fit for the Oem Cadillac sleeve ... Gap be gone .. !
The horn parts was a bit of work to load into the adapter .. Holes didn't line up plus the hole for the plastic nose needed to be drilled larger .. Small stuff ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Sure has been a major chore working the column from one end to the other ..
Do think once it's installed back in the truck and grinning like a alligator, it'll be worth the effort and expense ?
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Getting trick with the column ..
Steering wheel soon to be mounted to the adapter ..
Also got the tilt lever with a switch in the end of it to install on the column .. It controls the power cowl vent ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Note the button in the tilt lever ..
Remember the power cowl vent ?
Almost done with the column ...
Shorty81
Baby Boomer
North West ohio
Darren
That turned out REALLY nice!!!
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Thanks Man ..
Was wanting to see a better color match, but that's not in the cards ...
Don't want too, thinking about reshooting the dash, that was a job the first time around !
Carb'ed Vortec 350
Thanks Man ..
Looks great to me. But, if you're the one that it'll grind on, you have to decide. I personally wouldn't even notice it.
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Moving on to the wiring ...
Since there will be a boatload of wires going though the firewall I got this ...
Drilling a 1-1/2" hole in the wall for all the shi ... errrr stuff to go though, then this chuck of billet will cap the hole and the wires has a 1-5/8" grommet hole at the bottom ...
So many holes to fill and one to drill ..
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Well, it's like saying bye to a old friend ..
Sold the THM 400 trans that was in the Binder ...
It served me well for many years ..
Here's it's new home ...
800 HP ...
New owner going to install a trans brake and a 5,500 rpm stall converter and go sling some mud !!
Showed him my 4X4 and he wants to see it sling some mud too ...
nixon22
