Gimme some basics
Jppr26
Deer island
V20 custom deluxe
I got a 87 v20 4x4 with a tbi 350 and a 4 speed, I'm not looking for anything crazy as my wrenching ability is kinda limited,(no full rehuild type stuff) but I would like to do some work to the motor for some more power/performance. What is some entry level stuff that will do the trick
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Headers, aluminum intake, distributor, carb. Maybe cam and lifters but that’s a bit more involved
Rusty Nail
Rusty
350sbc
Change ;
The spark plugs .
The fuel filter.
The spark plug wires.
The air filter.
The PCV valve.
The charcoal canister filter.
The transmission filter.
The differential fluids.
The transfer case fluid.
The u-joints.
The belts.
The gas cap.
Lube the chassis.
Rotate the tires.
Then ask again!
4WDKC
Southern Florida
Kacy
I have a v10, the problem with these is the efi is old and noone wants to tune them with the exception of a few, some of them are terrible and some are good. Reason I mention this is because this engine has low compression and a small cam not making much power at all and to remedy that situation you will need to tune the efi.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I would say a good baby step is to delete the air injection and the catalytic converter(s). I wouldn’t do the headers all at once myself because that’s a decent-sized job. There’s less to go wrong if you do that in two steps. Like Kacy said, you don’t have a lot of wiggle room within the factory engine management parameters. If you figure that part out, that opens you up to cam and timing set, intake, heads, injector/throttle body upgrades, pump upgrade, a hotter coil, etc. They can be made into respectable machines using all the Rochester/Delco-Remy goodies you have in front of you, but it’s not like the Gen III guys who are completely ubiquitous with their tuning BS. It’s a cottage industry focused at a very slim, niche market.
@Daveo91Burb
Camar068
10 yrs Air Force
get a book that shows the complete top to bottom rebuild process of a 350. The one I was given when I was young explained how it works also. After reading that, messing with heads n such wasn't as intimidating.
jturner
