- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Started winterizing the burban today. Got my grill cover installed.
Piece of galvanized sheeting from Home Deopt with a few holes drilled in it and some Nylon Ties.
I put wide weather stripping on the back so it doesn't scrape up the grill, emblem and won't vibrate and be noisy.
Installing the nylon ties. Got to bend them in half so you can get it back out from behind the grill.
Finished. Still room on the sides for some air intake. This makes a big difference when the temps are in the teens and 20's like what we have coming here next week.
Dug out a heated dipstick my old man had laying around the garage for years. Plugged it in and it got hot quick. But the f'n thing is too short, and the dipstick tube has a bend it won't go through. I'll have to pick up a block heater from somewhere.
Also busted out the Silicone spray. Hit the hubs, window channels, door locks and strikers. Silicone spray works good for these areas on old trucks in the winter time. Keeps them lubed and repels ice and ****. Especially good for the window channels in cold weather on older trucks with tired power window systems.
Also hung a sheet up behind the second seat to block cold air from the unheated, rusty, drafty stinky ass of the Burb. Used a piece of 1/2 PVC, and two pipe clamps from Home Depot and mounted it using existing headliner trim screws. Please ignore the push pin in the ceiling.
