Gauge cluster question
hugedogleg
Stephenville, Texas
Austin
3/4 Ton 4x4
Alright guys, I need a little help. I have an 87 custom deluxe that I am building. I would like to upgrade my gauge cluster to include one with a tach. I have found several on eBay but they look to be out of mid 70's trucks or blazers. I am also upgrading to a 454(out of an 89) and want the 0-80 psi oil gauge. The problem is I don't want to spend the arm and a leg on one then it not work in my truck. Let me also say that this is my first build and am by no means a mechanic so I was curious if there is a way to know that the gauge cluster will work in my truck. If this has already been addressed can you direct me to the right thread. Thanks in advance.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
You can use a 1978-89 gas tach cluster from any C/K truck all the way up to a C60. It will plug in (need clarification as to 1978-79 will plug in or not). The oil pressure gauge is also a plug in. The tach harness will be the only harness that will need to be run, there's power, ground and tach signal.
8T6K5
AZ
L98 350 TPI
Build your own....guy in my other forum did this beauty:
hugedogleg
Stephenville, Texas
Austin
3/4 Ton 4x4
Thanks guys. I like the custom job. Probably a lot better quality gauges too. Gonna try a stock cluster first.
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
I just recently did this very upgrade, and I have never looked back! I recommend it!
Todd Lemon
