Gauge Cluster needles
Gilmore
Eureka
Christopher
6.2L Diesel
So I committed a rookie mistake and while cleaning up my gauge cluster I broke my speedometer needle. I want to just go ahead and buy a new set for all of my gauges(this pic was before I broke the needle). Can anyone recommend a good place to get them? I have a 1984 Chevy Silverado K10. Guages in question are Fuel (Large), Speedometer (Large), Volts (small), Oil (small) & temp (small).
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Junkyard or LMC would be my thoughts. Been some discussion on the LMC gas gauge, though - IIRC they said it would fall when the key was off.
Best of luck !
Britt
Gilmore
Eureka
Christopher
6.2L Diesel
I already tried LMC and my only option is to replace the whole gauge @ $150 for the speedometer and $50 for the oil.
idahovette
Weiser Idaho
Perry
K20-K10
Some one on this site surely has extra gages and will come to your rescue!
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Gilmore
Eureka
Christopher
6.2L Diesel
I hope so I would love to find a place to buy aftermarket ones. I found through a lot of searching that is a sought after part.
QBuff02
Central IL
Quincy
I've got good take out volt, oil and temp gauges from an '82 sitting on a shelf in my garage at home. I can take pics of them when I get home tonight and you can tell me what you think they're worth. I'm thinking they interchange. Anyone want to jump in and verify this?
Gilmore
Eureka
Christopher
6.2L Diesel
That would be great if they are compatible.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
This is my old OEM fuel gauge. I got a new one from LMC. Needle would fall from 3-6 0'clock when near full when key off. When near empty, would fall from 9-6 0'clock when key off. Needle would return to correct position when started. I contacted LMC cause I thought it was defective. They sent me another new one and it did the same. I now have a new one in truck which I modified slightly to not fall very far cause it bugged me. I also have a new one extra. The old gauge worked, just bounced a lot. Lost it's dampening to hold very steady.
Any way, I think I can remove needle from old fuel gauge and send it to you.
It is orange, 1 3/4" long. I am not for certain that it will fit your speedo.
If you think it will fit or if someone knows for sure let me know.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Sorry man I took this to mean you were looking for aftermarket gauges. My bad.
Gilmore
Eureka
Christopher
6.2L Diesel
I think it will fit. I'll PM you to give me address and arrange to pay shipping.
MikeD
