Fuse block Bulk head harness
RoryH19
Rory
R10 Silverado SWB
Hello,
What year did the fuse block change from round tube to the blade style?
Assuming somewhere between 79 - 81.
Any issues in retrofitting the later blade style into the older trucks?
I would change the harness inside the cab and under the hood.
Thanks
RoryH19
Rory
R10 Silverado SWB
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
I used most of a 1985 wiring harness in my '76. Older headlight harness plugged in with no issues.
Termite_Delight
K2500 K2500
350 L33
You will have issues with the windshield wiper switch, unless you use the newer column. High beam switch on the floor is an easy rewire.
RoryH19
Rory
R10 Silverado SWB
I was thinking to use 81 - 83.
That way it has the same style dash mounted wiper switch. It would also keep the floor dimmer switch.
ali_c20
Austria
Alexander
C20, K5
79 has the blade style fuses. Dimmer switch on the floor and dash mounted wiper switch.
legopnuematic
Licensed Junk Dealer
MO
Spencer
My 79 is blade fuses as well.
