Full Floater vs Semi Floater - What's the diff?
Jaymez
Connecitcut
I've heard of semi floater rear ends. I've heard of full floater rear ends. WTF is the difference between the two?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Semi-floaters are heavy duty axles found in newer model trucks, but the bearings and axleshafts are made like a Corp 10 bolt or 12 bolt, the weight of the truck rests on the axleshaft bearings. A full floater, the weight of the truck sits on the wheel bearings in a seperate hub, and the axleshaft can actually be removed without jacking up the truck, removing the wheel or rear end cover, because there is no load on it.
nvrenuf
Mobile, Al.
Just to clarify, any axle that is designed to carry the weight on the axleshaft itself is a semi floater. This is not specific to newer model trucks.
Jaymez
Connecitcut
So a full floater is like what's typically found in the back of a 3500 series dually where you have to pull the axle off before you can remove the rear drums and a semi floater is what I've got in my S10 and V10?
nvrenuf
Mobile, Al.
Exactly. Just look for the tell tale hub poking out for full floater id.
crazy4offroad
Curt
K-10
350/SM465/NP205
Yeah I had "semi-floater 14 bolt" stuck in my head.
wilson79
