Fuel Tank Relocation
Donald
Loris SC.
Don
GMC 1500
Hi to all , I have a 85 GMC short bed (under construction) I would like to install a blazer rear tank and get rid of the side tank . Has anyone done this , I searched and could not find a thread about this . I want to use the smaller tank 20 gal. and would like to install a throttle body fuel injection . If I use a 87 tank and sender does anyone know of a fuel pump that will fit the sender unit and have 65 lbs. of pressure . The stock pump for the 87 is only 35lbs.
I have been reading a lot of the threads and the amount of knowledge you guys have is amazing . Don
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Donald
Loris SC.
Don
GMC 1500
OK , I have done some looking around and this is what I have found . Using a 87 blazer tank and sending unit to get 65 lbs. pressure you need for a fuel tech throttle body fuel injection use a Delco EP381 fuel pump . Don
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
Doesn't the Chevy TBI like about 13# of fuel pressure? Inquiring minds want to know.
Moderator Administrator
i made a write up gas tank relocation. I believe it's a sticky. let me see if I can find it.
Donald
Loris SC.
Don
GMC 1500
Sorry about the 35 lbs. for the stock 87 fuel pump , I worked for Nissan and there throttle body used 35 lbs. Thanks Old77 for the info. Now all I need is time to do it . Don
nixon22
