Fuel lines.
Biggin14
Ohio
Tyler
V20
Alright I don't know if I'm in the right place or not. I have an 87 v20 with tbi and I can't find fuel lines anywhere and I was just gonna run ptfe line. Has anyone done this and can tell me exactly what I need. Thank you in advanced.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
You have an airport with an aircraft parts business close? They usually have fuel line.
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
Check with "lines to go". We use them for stuff that's discontinued at my shop
Biggin14
Ohio
Tyler
V20
I've looked in there multiple times the don't really have anything for 87
350 w/203
Can I ask why???
You want something that is rated for handling fossil fuels/solvents.
Plus, any time you run hose; you want it to be as short as possible.
You don't want to become a 'car-b-que'.
AKguy
Alaska
Randy
From Hyper Racing page:
“PTFE has supreme chemical resistance and will not break down even after years of use with methanol. Regular rubber (EDM or NBR, which is what almost all fuel lines are made from) begins to break down even before one year wreaking havoc on your fuel delivery system and injector nozzles. Rubber hoses can even begin to leak or spray fuel, which can be pretty dangerous.”
From Hot Rod Fuel Hose:
“The first - PTFE hose acts as a vapor barrier and prevents gasoline odors from seeping out into the garage or shop when your ride is taking a break from doing burn outs.
Second - PTFE lined hose has supreme chemical resistance and supports a bunch of automotive fluids that regular rubber just can't. The most common of which is blended gasoline containing ethanol. Regular rubber hoses break down from exposure to this gasoline and eventually degrade to the point where they may begin to leak or spray fuel - Pretty dangerous.
Third - PTFE lined hose has a very high temperature tolerance - In fact the hose that is sold by Hot Rod fuel hose has a working temperature range of -60 degrees Celsius to over +200 degree Celsius. Perfect for running plumbing on your hot rod.
Fourth- Hot Rod fuel hose PTFE lined hose has a very high working pressure, again making sure you can use it for all types of automotive and hot rod applications. AN6 size is good to 2500PSI and AN8 is good to 2000 PSI - more than enough pressure for even the most demanding applications. “
Take a look at the SAE J30R9 specification for EFI fuel hose. It’s rubber hose, but designed to hold up to modern fuel and fuel pressures. Much pricier than the old rubber hose, but should hold up a lot better. Most parts stores have it by the foot, but online sources are cheaper.
Also remember that the long runs of fuel line are already metal, with the longest rubber line being the ones connecting the tank solenoid to the sending units.
ali_c20
Austria
Alexander
C20, K5
The SAE J30R9 fuel hose uses a fluoro elastomer inner liner that will withstand up to 180 psi and 300 degrees. It is approved for all fuel blends including straight methanol, and the outer coating is also ozone- and abrasion-resistant. It's way cheaper than PTFE stuff and easier to work with.
https://www.summitracing.com/parts/cel-65149?rrec=true
Which lines are you replacing? Just the short braided ones. Or has something happened to your steel lines?
that_orange_c10
