Fuel hose clamp tightness ???
84 c10 o skool
Houston, Tex
Steven
383 stroker
Hey guys, this might be a dumb question...
How tight do yall tighten your hose clamps.
I'm replacing fuel tanks and was jus wondering.
I tighten them until the hose doesn't slip off the fitting.
If I can pull the hose off I tighten till the hose doesn't slide off.
Thanks yall.
350runner
tx
Ceasar
I usually tighten then till i see em start to squeeze the hose a little bit.
I usually tighten them until the surface of the clamp is flush with the skin of the hose.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I usually tighten them until the hose just barely starts to squeeze out of the grooves, any farther you're pretty much cutting into the hose
alwaysbroken
