Fuel Hose: Bulk off-the-shelf vs Fuel Injection Rated
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Back Story:
Approximately 2 years ago I purchased a 1986 C30 Big Dooley. It had a few issues including a bad fuel pump, and a bad fuel sender. At that time I replaced both components as well as all the associated rubber fuel lines. I used the bulk fuel lines you can get at any auto parts store (Advance Auto in this instance) and they are rated SAE 30R6.
Flash-Forward to Last Week:
So last weekend I started getting a very strong smell of fuel in the cab - so much so that it was sickening. So I popped the hood and the first thing I noticed was the fuel line going to the pump. It was cracked all the way along its length with string showing through. It was leaking A TON at the pump, and was actually pooling on the engine cross-member. It would not have taken much to go BOOM.
Yesterday:
After I parked the truck for the week I went ahead and pulled all the rubber fuel lines out, dropped the passenger fuel tank (leaving the driver's for later as I don't use it) and removed all the 2-year old rubber lines. All were marked SAE 30R6. All showed signs in varying degrees of the same problem.
SAE 30R6 vs 30R9:
I did some research on the topic, and it would appear that fuel hose sold at auto parts stores (the stuff you get when you say "I need some fuel hose please") is rated SAE 30R6. This means it is rated for old-school fuel - NOT modern ethanol-laced fuels. What I experienced is the result of that.
It turns out that another hose is made with an SAE 30R9 rating. These hoses are generally referred to as "Fuel Injection Hose" because they are rated for a much higher pressure - but more importantly they are rated for use with ALL fuel types including alcohols, fuel-oils, diesels, etc etc. They don't tell you this at the parts store. 30R9 is much more expensive than the old school stuff, but it is built to handle government-required bull-sh... sorry ethonol-mixed fuels we find at 99% of gas stations today.
This link talks about this topic in detail. They refer to SAE 30R7 in this article, but the same goes for the 30R6 found in auto parts stores. They key is where they talk about the Flouroelastomer (FKM). This is what makes these lines what they are.
http://www.gates.com/oreilly/tech_ti...elLineHose.pdf
The Moral of the Story:
Ask for SAE 30R9 Fuel Injection Hose when replacing rubber fuel hoses. You don't want to experience an engine fire, or like me get off lucky and simply have to replace them all again. Do it right the first time!!!
firebane
Calgary, AB
Curtis
The thing is though this is more consumer education than anything else. Yes ethanol is here and most likely will not be going anywhere anytime soon which is why the 30R6 hose can be sold for. Don't forget fuel line has MANY uses other than fuel line such as being used for vacuum lines.
I do suggest to everyone to understand that ethanol is an alcohol and because of such rubber that isn't meant to stand up to it will dry rot and crack. I discovered this on my motorbike as the tank seal after a year was cracking and deteriorating badly.
Ethanol fuel can suck a fat one.
Carb'ed Vortec 350
Thanks for the heads-up. That's good to know. Now I need to go check my lines to make sure they are the right kind.
MadOgre
NA
NA
NA
NA
NA
What I would like to find is the ATF specific hose for my power steering ???
MadOgre
NA
NA
NA
NA
NA
I just need a length of hose that I can cut and install for the return lines
da_raabi
FloriDUH
Adam
c30
What the hell is with all the links in my post? I didn't want anything linked, other than the one I posted. When I hover over one it says "Link added by VigLink" and it sends me to random amazon pages and stuff. :wtf2:
da_raabi
FloriDUH
Adam
c30
Dammit it did it in that one too! Hmmm... I could have fun with this if I wanted...
MikeB
My local O'Reilly auto parts store has Hayden and Gates ATF hose in 3 sizes.
But wait, power steering hoses may not be the same as ATF hoses. If your PS hose lengths or fittings are not standard for your year/model truck, then find a hydraulic hose company in your area. I have two of them within 15 miles that will make custom PS and A/C hoses.
MikeB
Revenue for the site owners. These forums cost money to maintain.
MadOgre
NA
NA
NA
NA
NA
Return lines don't have crimped fittings.
da_raabi
FloriDUH
Adam
c30
Oh ok. As long as its meant to be there. I thought the site had got bugged or something.
Moderator
Trans fluid and ATF are the same thing when it comes to most anything GM. Just go to the parts store and ask for trans cooler hose in the size you need for your power steering line (return). If they are idiots (likely) then they will come back to the counter with fuel hose and you will have to tell them again you need trans cooler hose and go look again.
rafamartz
