fuel delivery set up
boomjuice86
Maine
Patrick
High Sierra
in tank fuel pump or external fuel pump? just dropped in a 454 with no fuel pump set up on the block since it was originally TBI. truck is an 86 short bed gmc. question is do i set it up with a inline fuel pump or put in an electric in tank pump? basically which set up is better? its not a worked motor just rebuilt, 750cfm carb, pavement pounder. any help on this topic would be greatly appreciated. thanks.
1973c10
Don
I am no expert on this
That being said I have ran Holley electric fuel pump
on my big blocks from my hot rod go fast motors to my motorhome
I installed them on the inside frame rail back by the tank
and depending on what pump you get and what carburetor you are using
you may need to use a fuel pressure regulator
fussfeld
east coast
j
c-10
4.3 v-6 262CID
If the truck was originally TBI, then is the original fuel pump still in the tank?
boomjuice86
Maine
Patrick
High Sierra
original set up in an 86 is carburated. old motor had the fuel pump on the block. new motor is a gen 6 454 big block, no fuel pump set up on the block. considered running a frame rail pump just near the tank and enough pressure to get up to the carb with correct fuel amount supply.
highdesertrange
kalifornia
mike
k30
if you are running a carb I would use a mechanical pump. highdesertranger
1973c10
Don
I have gen 6 454 in my motorhome with a pump on frame rail
one on my 73 C10 with a 454 and one on my
75 puller truck with a 454 and have had No problems ever all with carburetor
87scotty
Central il
Andrew
V20
5.7 for now
Do you regulate and send rest back through regulator?
87scotty
Central il
Andrew
V20
5.7 for now
Reason why i ask i got an 87 im doing a built 454 i have factory dual electric tanks i feel itd be better to stick with them and regulate rather than a mechanical pump!
1973c10
Don
Here is what I used on my 75 chev truck with dual tanks
http://www.speedwaymotors.com/Holle...gn=CSEGOOGLE&gclid=CITEssW9hdACFQqPfgodyjECug
Or you can use the Holley Carburetor Bypass Style Fuel Pressure Regulators 12-803BP
https://www.summitracing.com/parts/...se1-_-holley&gclid=CJ7jp_jBhdACFcRcfgodcG4LYw
my other 2 ( motorhome and stepside ) have single tanks with no return
1973c10
Don
Did you get done ??
redrosec10
