Front drive shaft- lost orientation marks!!
scenic760
SoCal
Suburban K10
Hey All,
I replied on another front driveshaft rebuild thread but I thought I should probably post my own as no to hijack!
So I pulled the front driveshaft (along with the engine, transmission, transfer case haha) and going through the process of replacing the ujoints and center joint...well after heating up 12 ends caps to get the nylon out and scrubbing them down with paint thinner and acetone, I lost my orientation marks!!
I think I may have been able to keep the front and back in phase as there is a double spline notch on top, directly inline with the back yoke and there is a casting number that will orientate right side up but then the center connector leaves me a 50/50? Does anyone know if there is a way to tell?!
Or do I just put it back together and get it balanced?!
Thanks!
Moderator
I'm not aware if there's a way. But that's a good excuse to have it balanced when you are done, lol.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
They should be keyed to fit one another?
scenic760
SoCal
Suburban K10
Keyed? I'm not sure I follow?
On another note, I took out the rear driveshaft ujoints tonight and it looks like the yoke has seen some harsh times..should I replace this?
Ilgy84
North Carolina
matthew
M1008
6.2 diesel
With a double cardan joint at one end of the shaft the orientation of the u-joint at the other end doesn't matter. U- joint phase only matters if there's 1 u- joint at each end of the shaft.
Moderator
But if the double cardan has a heavy side, it will throw off the shaft balance if it is installed 180* from how it originally was.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
50-50 chance?...
scenic760
SoCal
Suburban K10
That what I was looking at on the H-joint as it looks like it had some extra material on one side...I was then thinking that maybe that is the ONLY balanced part in a double cardan setup? If that joint was off balance to either side, wouldn't it throw the entire shaft off?
Moderator
Are there no balance weights welded to the tube?
rpcraft
Robert
LS 6.0 364 CID
If its a front driveshaft It shouldn't really matter. How often are you doing highway speeds in 4 high?
Moderator
When I was still driving mine all the time, that happened very often. Usually all winter. Not engaged in 4 high, but the hubs locked and shaft spinning.
scenic760
SoCal
Suburban K10
There indeed is a weight on the tube...
I'm not opposed to taking it and having both shafts balanced (anyone have any idea how much that should run me?) as I am replacing 5 u-joints in total, a ball joint at the H and I'm also replacing the rear driveshaft yoke. All of the snap rings on the rear shaft quite literally snapped in half when I squeezed them with pliers, along with a section of the outer retaining groove on the yoke.
If I plan on taking the driveshafts to get balanced, does it really matter how they go back together? Also should I walk them in or is it something they need to do on the truck?
Moderator
I haven't had it done in years, but I think the last time I had a shaft balanced, it was around 60 bucks. I brought the shaft to them.
Raider L
Shreveport, LA
William
It looks like the needle bearings locked up and spun the cap in that yoke pic. Man! And I can't imagine how the snap ring lip broke off in that one place. Maybe something hit it? I'd chunk it. It could also be bent to, somehow.
ronscoms66
