Fresh resto with engine problems? Wont stay running
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Got a new problem now.. Once the exhaust was installed the truck ran sluggish and would stumble off idle. Now today it wont even start up. I can get it to start if I hold the gas pedal down, seems to run good while I am doing that. Once I release it it will drop to about 400 rpm then die. No check engine light and I know its not a fuel problem. I unplugged the TPS and nothing changed, any ideas?? I need help bad!
87 GMC R10 5.7 TBI
Georgeb
Wisconsin
George
K10 Burb Z71
first place I would check is the IAC valve. Try resetting it to zero. Can you read data like with a laptop or something? It would be nice to know if it moves and how far open it is at startup.
Georgeb
Wisconsin
George
K10 Burb Z71
Also someone on here has a great troubleshooting guide for TBI perhaps they will post it. The best tool I have is my ability to connect via my laptop.
Georgeb
Wisconsin
George
K10 Burb Z71
Found it!
http://www.gmsquarebody.com/forum/showthread.php?t=8719
FenderBanger
