FOUND WTB: Transfer Case Skid Plate
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Also looking for the heavy steel Transfer Case Skid Plate, 4WD (obviously)
'87-'91 V1, 2, 3
'87-'91 1/2, 3/4, & 1 ton 4WD
Pickup, Blazer/Jimmy or Suburban
"Wavy" or "S" style cross member
'85-'86 is different and will NOT work
The part is for a '91 V2500
Suburban
Strick
Dunn, NC
Harold
C20 Crew
What year are you looking for?
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
It is for a '91 V2500 Suburban
'87-'91 will work
'85-'86 will NOT work
Thank you
Strick
Dunn, NC
Harold
C20 Crew
Does that have the "W" shaped crossmember?
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Just snapped these pictures.
I've updated this post to reflect that it is the "Wavy" or "S" style cross member.
Not the "W" style.
Moderator
That's what is commonly called the "wavy" or "S" style crossmember. It was used '87-'91.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Okay, thanks.
Well that makes sense since it's a 91
Strick
Dunn, NC
Harold
C20 Crew
I have one for that "W".
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Sorry I got a little confused here.
I wasn't familiar with the differences in the crossmembers.
So on my '91 Suburban, (see pictures) is it correct that I have the "W" or wavy crossmember? And this is also known as "S" style crossmember?
Thank you.
Moderator
They are kind of confusing, lol. The "W" crossmember was used in '85-'86. The "W" crossmember looks like the passenger side of your crossmember, but on both sides. There's a thread around here about the crossmembers, I'll see if I can find it.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Thank you!
Moderator
It's kind of a long read, but there's lots of good info in there.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Thanks for sharing that link.
I'll study it!
Strick
Dunn, NC
Harold
C20 Crew
Thank you!
I cannot attach a photo in the message board...but I can in these threads... This crossmember is from an 86 K5 and is the "W" shape.
Strickland
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Hey thanks for sending the pics.
I'm going to have to compare it and make sure we have the same crossmember here.
Do you know how much you want for just the skid plate and the bolts holding it on to the crossmember?
Thanks again.
Jeremy89
