Flywheel cover replacement
BGPick
Illinois
C20 2WD
6.2L Detroit Diesel
Hello guys, just bought an 86 C20 with the 6.2L diesel. Its automatic but I'm not sure what transmission I have. The flywheel housing cover is missing.
#1 - Anyone know where I can find a replacement?
#2 - Is there some sort of gasket for it also? Or just direct bolt on AS IS.
Thanks!
yevgenievich
Viktor
sad
very sad
less sad
Direct bolt in, i had one laying around somewhere
BGPick
Illinois
C20 2WD
6.2L Detroit Diesel
I would be happy to pay you for it if you can find it! Message me privately If you want, thanks!
yevgenievich
Viktor
sad
very sad
less sad
I will check tonight to verify it had not walked off
BGPick
Illinois
C20 2WD
6.2L Detroit Diesel
Thank you sir! I appreciate it!
BGPick
Illinois
C20 2WD
6.2L Detroit Diesel
Still looking for one of these! If anyone has the oem part number that would be great!
I see the “universal” abs plastic replacement covers but that seems like a bad idea to me.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
On a 2WD it really doesn't matter. It's just to keep it from winding up string or vacuuming up other stuff from the road. On a 4WD OTOH it's structural.
78C10BigTen
pennsylvannia
C10 BIG TEN
Depending on your trans i have one for a th350 i can part with...
BGPick
Illinois
C20 2WD
6.2L Detroit Diesel
I believe that I have the TH 700R4 - automatic.
78C10BigTen
pennsylvannia
C10 BIG TEN
Not sure if theyd be the same cover
78C10BigTen
pennsylvannia
C10 BIG TEN
A jump on autozones website shows a universal one with oblong holes and you cut the starter hole depending on what you need. Not sure if this would work or not
yevgenievich
Viktor
sad
very sad
less sad
I finally found one
BGPick
Illinois
C20 2WD
6.2L Detroit Diesel
Yes sir. That’s why I don’t want it!! I just can’t find a metal one.
Misty Blue
