floor console with dubble din stereo
kgc4160
wahington
kelly
has anyone put a dubble din stereo in a floor console.. been thinking about this for awhile.. 81 c10.. i am keeping the stock a/m radio in its place but want to upgrade..
Auburn, Washington
We used to do that when we were kids so as not to tear up the original stuff in old cars.
The only limit is your imagination and ability to build a console. Doubt there’s one produced commercially. After that it’s just wiring up a stereo.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Grit dog, funny the difference in generations! We just put cassette players in with oversized Craig rear speakers and we thought we were cutting edge. Easton and I are installing his stereo this week.. this old guy trying to understand all this amp and sub woofer stuff is crazy… seems like overkill in a old square body but it’s his project and money.. I learned what a Ferrell was this week though..
WP29P4A
Nevada
Sierra Classic V1500
Did you also learn the main reason NOT to use ferrules? We used to debate this with clients that didn't like the look of several speaker wires coming through a hole in a wall plate. They wanted us to shorten the wires, connect them to a plate with connectors on the back and then use connectors on both ends of the wire going from the plate to the speakers or the back of the stereo receiver.
The most simple analogy we could get them to visualize and understand, was to ask them if they cut their garden hose into several pieces, and then tape it back together again, does that make the hose work better. The next question, do you want your audio system to sound the best it can, or do you want to spend extra money for parts and labor that no one will ever see, that degrades the sound that you paid good money for.
The science comes down to contact area, fine stranded (quality) audio wire makes the best connection when properly stripped so individual strands are not removed while stripping the wire, then inserted in connector and properly tightened. EVERY extra connection you put between the amp and speaker that is un-necessary, degrades the sound. Every connector you put between amp and speaker is another opportunity for a marginal connection. Every time you change your signal path from stranded wire to solid conductor and back again, you alter the signal, and not in a good way.
That's my 2 cent opinion based on more than 40 years of high end audio/video installation and repair. On high end installs we use a liquid that you apply to the wire before inserting it into the connector to enhance the connection, more surface contact.
Ifyasquintitsmint
Denver
I just bought a center console and am going to try fabbing up a mount for a double din into it. Should fit nicely between my bucket seats, be hidden and look stock ish.
Randy and Easton
Randy
C-10 LWB
Did it for safety sake. I have one or two wild strands of 4GA touching ground will not be a good outcome. These kids don’t know what good sound is anyway… with 2 12” subs? In a square cab? And a 150 watt amp?
WP29P4A
Nevada
Should sound really good with that system, I get what you mean with wires touching. Some of the high power amplifiers almost have enough power to arc weld.
I know you got what you need but I'll put this out there in case it helps anyone. Mazda b series pickups and Ford festivas used these under dash they usually just have a pocket in them,but an easy way to put a stereo in anything.
Terry Wilkerson
Kansas
Terry
GMC 1500
This for a shoebox I'm building. As Grit dog said imagination and planning. I pretty happy with it. It's one of the last things before I call the shoebox done.
84GMCSierra
Central Arizona
C2500
I spotted this one doing research for my own, it’s my favorite so far.
I like that one too. I like the fact that the speakers are pretty close to being flush with the sides.
JohnJ1984
