Fleetside bed floor
bucata206
Silverdale WA
Anthony
Does anyone have any creative/less expensive solutions to fixing/replacing a rusted out bed floor? I'm needing to replace my bed floor but I also don't want to spend $600 for a new floor....
74 Shortbed
Sheet metal, wood, diamond plate, really depends on what you do with the truck and what you like.
marks86
Latham, NY
Mark
12v Cummins
junkyard, but 99% or original bed floors have rusted rails on them.
SDJunkMan
Black Hills of South Dakota
Jeff
Too bad you are not closer, I have a really clean one I was going to put in a dully I had, been sitting in the shop for years.
bucata206
Silverdale WA
Anthony
Unfortunately the junk yards here like to fill the beds high with parts so you cant see the floor. That and being in Washington= tons'o'rust
marks86
Latham, NY
Mark
12v Cummins
thats just plain stupid, Im in the same boat. Being from NY
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I lined my bed with 14 gauge sheet steel...welded the seams and had it spray lined. The sheets of 14 gauge were $185 and the spray lining was $300. I did this for two reasons........all the donor bed floors were dented beyond any repair but the sides were good and i cut out the center section for my frame notch anyways and wanted to smooth out the inside. The added weight helps for traction, the bedlining is seemless and quiets down any possible rattles. I used self tapping screws to attach the steel sheet to the existing floor of the bed.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Purdy
bucata206
Silverdale WA
Anthony
This looks great! I like this idea
74 Shortbed
That came out real nice..
350 w/203
What brand spray lining did you use?
smoothandlow84
Steve
Thanks everyone for the kudos...the bedliner was sprayed in by "Universal Bedliners of Mesa, Az". I met the owner at the sand sport super show a few years back in Scottsdale, Az. Hisguys did a fantastic job. Only problem I had was drainage, but I just drilled drain holes in the front corners. Before the drain holes, it was quite the "fish tank"
smoothandlow84
Steve
Hindsight...I just wish that I cut out and raised the rear tubs.
Don5
West Virginia
Don
k15
That turned out real nice!
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
that's crazy, over here in Spokane we have tons of square that are pretty rust free.
NateP350
