First post with Questions
Auburn, Washington
If it doesn’t have a few squeaks or strange noises it means something is probably not working!
But yeah idk what it could be.
Your front suspension, is it soft or is it just really low clearance to the fender wells? Bump stops in and engaging before it bottoms out?
Are the shocks blown? Shocks shouldn’t be keeping it from bottoming out per se though. But they’d let it bounce over a speed bump and if the clearance is real tight, that could be part of your issue.
Just a couple things to look at.
bbfishey
Mississippi
Brent
Chevrolet
It's real soft, like the springs and shocks are blown. The steering feels a little squishy as well, but its got new components down the tree.
mxer147
Colorado
Jack
k20
Exhaust rubbing from a loose or improperly placed hanger will result in a squeak, depending where it’s at it will resonate into the cab. You could also increase the radio volume and keep the windows down to drown out the squeak, that’s the if it’s not broken don’t fix it theory. Nice looking truck!
Auburn, Washington
If the shocks are blown it will bounce 2-3-4 times after a bump. Easy to diagnose.
bbfishey
Mississippi
Brent
Chevrolet
After trying all the suggestions offered I believe I've narrowed it down to the dash. It squeaks constantly at a low tone until I press down on the center of the dash near the windshield. The dash appears to be mounted securely though there may be loose bolts underneath. I guess my next step is to crawl up under it and see if I can find loose or missing bolts/screws.
84c10Tony
Howdy!
In, but not from So Cal
Tony
Was 84
01 Sienna
Welcome to the forum, loose screw an all! My old 84 was like that and had to tighten up panel screws, it would go away for a while. Replace your shocks, or up it a bit, either way, it will give you ______ till you ______ the ______then bing up on the axelz....and don't spel it like that. Have fun, welcome to the nut house.
mattsk8
Michigan
I'd pull the dash pad and check where everything mounts. Take it for a drive with the dash pad removed and see if the squeak is gone. If it is gone, figure out how to tighten the point of contact where the pad is squeaking, or use some sort of adhesive gasket or strip caulk at the point that it's squeaking. Issues like this are a process of elimination, just keep taking it apart and wiggling things until you find your squeak.
bbfishey
Mississippi
Brent
Chevrolet
Good morning all!
I found my squeak. It was in the dash. There is a support rod that runs from the outside edge of the under-dash, through the firewall into the engine-bay. This support rod had lost the nut on the end of it and was allowing the dash to shake when idling or moving. I replaced the nut, adding a lock washer, and BAM, problem solved.
I can't believe it was so easy. Bettye White-truck 0, owner 1!
Thanks for all the ideas and support!
FenderBanger
