SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
More tonight and I'll research this a little but maybe you know off hand. So my knock sensor is connected with a blue wire and is not shielded in anyway. Double checked the module wiring as well. It's that blue wire you can seeAs discussed before, my '82 has a shielded wire to the sensor. Most important is to have a good connection to the core wire as the sensor is actually a microphone generating current.
For the test I was shown hitting the exhaust manifold with a wrench. I have always used a 3/4" wrench that may have a different sound than the hammer.
I'm thinking there may have been a change between 82 and 84 but I will research that a little tonight. I tried to do the tap test with an adjustable wrench. I swear I could hear the idle speed drop back a bit, but when I climbed up on the support with the timing light I could not see the timing being pulled back. Possibly I can't tap fast enough when I'm up top or the sound of the engine speed dropping back was an auditory illusion because of the tapping noise I was making. We will see. Looks likely I'll need to go out tonight so will see if there is a noticeable differance.
