SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Reading through this again, there is part of the ESC you have wrong, or it is different than my 1982 305 system. I looked at vacuum diagrams posted for the 1984 305 and they have the same vacuum to the distributor as my 305.
The vacuum advance uses what is called trapped vacuum spark. It only traps and holds vacuum to the advance when the engine is stone cold. The vacuum is sourced from both manifold and ported and held by a check valve. It uses the strongest vacuum. As the engine warms, the thermal vacuum switch now connects the vacuum past the check valve. I believe to just ported vacuum. (need to check that, can't remember) There is a cindered iron bleed on the thermal switch that allows the trapped vacuum to bleed off if the engine stalls when cold.
The ESC has no electrical control to the vacuum system that goes to the distributor advance. The ESC delays the spark timing electrically 4* when triggered. Another 4* if still triggered. Yes the ESC does see engine vacuum, and uses that to control the spark timing too, electrically, not by changing the vacuum to the distributor.
Ok thanks. I have not re-read all if the tread, though I have been meaning to so I'm not 100% sure of what I have said before.
I am aware of the original vacuum routing however the PO had pretty much stripped it all off before I got it so stuff like the check valve and bleed off are gone. When the vacuum advance was hooked up and my plan is to run it to ported because that's basically the closest option I have. The PO also installed an Edelbrock carb, so I don't have the exact same connections a Q-jet would have, but of course there is ported and manifold.
I could not remember how much timing the ESC was capable of pulling so thank you for mentioning that.
I've got to get the EGR functioning and the knock sensor and see where I'm at at that point. I'm going to pull the carb and attempt to clean the passages but suspect that it will end in failure and the manifold will need to come off or possibly be replaced. There are some Edelbrock performers with EGR used on E-bay for about $150, and I will think about that possibility for a bit.
