By now, everything from the battery to the ignition has been measured and/or replaced:
- +12V cable from starter motor to fuse box
- from fuse box to starter switch
- from starter switch to neutral switch and distribution cap
- from neutral switch to starter motor solenoid
- new distribution cap + rotor + HEI module + ignition coil + spark plugs + spark plug wires
Unfortunately, this had no effect..
While measuring the ignition timing, I manually pull the throttle on the carburetor and felt around for leaks with my fingers. Exactly behind the heatpipe choke unit, I felt a strong suction effect. The suction spot was not visible! but I removed the Impco set and carburetor, and this is what came to light! see pics
I had a spare gasket but it's a different model see pic. can I use this gasket? a small section between the throttle valves is then not covered
@75gmck25 the intake manifold is original cast iron
