Dropping Drive Shaft- siezed bolts....any ideas?
Ken B
indiana
ken
So I was able to remove 1 bolt so far. I didnt want to start rounding off bolt heads.
Soaking with PB blaster. Anyone with experience removing these bolts undamaged would be helpful.
I am looking to drop drive shaft to pull engine and trans. this is the last connection, except motor mounts of course.
Thanks
They should just come right out. Make sure you use the right sized 6 point wrench. Sockets are hard to get on and a 12-point socket can round them off.
Turbo4whl
Downingtown, PA
Wayne
Apply heat to the yoke where the bolt threads in. Sometimes heat then cool and then heat again works best. While the yoke is hot, remove the bolt.
Smack the head of the bolts a couple of times with a hammer and punch not hard enough to mushroom the head but hard enough to jar the bolt also try tightening just a hair then loosening.
Ken B
indiana
ken
damn who knew it would be hard to find a 6point socket....everything is 12 point.
You need more tools!
When you do get those out, be good to yourself and replace them.
Ken B
indiana
ken
Oh they are getting replaced for sure.
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
part # 14018700. still available from gm. We still keep them in stock at dealer I work for.
Ken B
indiana
ken
Wow. I never woulda guessed dealer carried that
Washington
Yup heat the yoke not the bolt.
Hot as you can get it with mapp gas and if that doesn’t work, Acytlene torch.
Bhardiman1
