Drop shackles and hangers
ONEARMEDBANDITT
ga
matt
1500 choo choo customs
I put some drop shackles on my truck and took a leaf out and the top of the hanger is pretty much resting on the bottom of my bed I cut the bed supports.. what's the significance of the hangers will this give me more clearance? Thanks
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Drop hangers alone give you about 2 -2-1/2 inches of drop. If you want even more drop install a axle flip and that will give you up to 5 inches more drop.
ONEARMEDBANDITT
ga
matt
Right but will it give me more clearance from the top of the shackle to the bed?
smoothandlow84
Steve
If whatever you install lowers the truck, then you will lose clearance
J Knight
Baytown TX
82 Chevy
350ci
Can you post a pic?
Supersoaker
Littleton nc
Donnie
6.0 ls
With the drop shackle you cut bed as you did for clearance .
the flip kit, less springs, will Not add or subtract from that spot
use a western chassis rear spring, front drop hanger for 2in of drop
EDNOMAD
