Drive shaft slipping and clanking
vgrn
NYC
vlad
gmc k15
small block 350
Any idea what transfer case this is? Every time I put the vehicle in reverse the rear drive shaft clanks/slips. Also everyone I’m driving and give it some gas it also clanks/slips. Some one test is knowledgeable with square bodies said that it’s probably the transfer case. Any ideas?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Looks like a np203, but im not a t case expert
Octane
Atlanta
Eddie
It looks like to me a Np203 chain driven fulltime unit.Chains can wear out and cause clunking and chain noise.Mine never has tho.As far as slipping,I dont know unless its actually jumping its chain gears.I would think if it got that bad it would fail completely very soon.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Yes, Vince is correct, 203 transfer case. The common failure is a stretched chain, then it jumps over the drive cogs and slips. If the rear U-joins are tight then you hear the noise amplified by the rear drive shaft.
The chain drives the front drive shaft, but it is located at the back of the transfer case. Has the system been modified to part time? Unlocking front hubs?
75gmck25
Northern Virginia
Bruce
Are you sure it’s the rear driveshaft?
With an NP203 the front driveshaft has a CV joint (double u-joint) on one end and a regular u-joint on the other end to handle the driveshaft angles as the suspension moves. If they dry out you get quite a bit of noise out of them.
Octane
Atlanta
Eddie
The front shaft cardon joints can go dry,there is a fitting for grease on them.(Two u joints with a shaft betwixt them).When they wear out they get noisy.
el chevy
corpus christi
manuel
r10
Mine does the same thing put in reverse clank loud that’s the only gear it does it with it’s a 2wheel drive though hope you find solution so I can get mine fixed thank you
Mudbeast2
