Drilled and slotted rotors
bigge31566
GA
Ervin
Im thinking of putting drilled and slotted rotors on my 83 C10 with 400 hp, has anyone ever did this or is it worth it
cmull
Williamsbug, Va/Radford, Va
Colin
I havent put a set on a truck, but I put a set on a VW Golf I had and I felt a difference. Made me more comfortable for sure! If you need to replace the rotors anyways I'd go for it!
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
My personal opinion is they are not worth the expense for a street truck strictly in terms of performance gains. They might run a bit cooler, but unless you're on a track I doubt you've experienced brake fade with the standard rotors. You would notice more stopping power with a quality set of pads. They shed water better than a solid rotor, but nearly every car on the road has non-drilled brakes and everyone seems to be stopping just fine.
All that aside, with the right wheels they look awesome! If you're running some aftermarket rims that show a lot the rotor area, and you have some extra cash laying around, then go for it.
I did it to mine, when I lowered my truck, even changed to the 1.25 spindles, rotors and calipers. like skysurfer said, you wont notice a huge difference, they to perform a lot better in wet weather, the do keep your pads cooler. I'm very happy with the upgrade, IMO well worth the money.
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
This will probably be the next real money I spend on the 'burb. I've had the front brakes extremely hot while towing. Slotted and drilled would probably have made a lot of difference.
kparris
