Door lock knob rod
TimB
CA
Tim
Where do I find this rod that comes up thru the top of the door panel to manually lock/unlock the door. My driver side was broken when I bought it.
Thanks for any help...
Tim
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I checked, and it doesn't look like they reproduce the door lock rod that comes off the actuator. I'd be heading to a junkyard to find one if I were you.
ajd89
Central Michigan
andrew
If you can't find one near by I've probably got one I can mail you if you pay shipping it' yours
TimB
CA
Tim
Thanks for the replies. Good to know I wasn't the only one that didn't see it in the aftermarket. I'll see if there are any yards around here with a truck but I'm in the middle of no where CA so fingers crossed. Might have to take you up on the offer ajdemello, thanks.
chengny
I was going to try to help you with a part number/availability last night. The parts DWG calls it simply "ROD" - nothing else, I figured it would be easy to pull your number. But then I looked at the parts LIST and the number of possible choices - Holy F*ck:
TimB
CA
Tim
Well I found it but of course it's discontinued... Any one have one of these laying around on a parts truck? I have a 79 C10 and it's the driver side rod thats broken. Thanks for the assistance so far.
BTW, part number is: 14039767 LH - 14039768 RH
chengny
Just as information, that part is used up through 1991 (and with the same P/N):
fmxr47
US
Justin
I was in the same boat and just found one locally on a parts truck
crowe-t
