Does anyone see a fusible in this pic?
kevinc
arizona
kevin
Nothing here looks like a standard fusible link to me. Maybe there is style here that I am not aware of. Thanks
nvrenuf
Mobile, Al.
No but there’s an inline fuse in that heavy pink wire where one probably use to be.
kevinc
arizona
kevin
"No but there’s an inline fuse in that heavy pink wire where one probably use to be."
That inline fuse should probably be replaced with a fusible link, assuming it is the wire feeding power to the horn relay. Do you agree? I've read that fuses are not an appropriate substitute for fusible links.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
They'll be closer down by the starter.
75gmck25
Northern Virginia
Bruce
Since my ‘75 K25 probably matches your ‘75 K20, I think I can help.
- the clear fuse holder on the left is the fuse (25 amp?) for the HVAC blower high speed. If it blows you will have no high speed on the blower. On mine the fuse holder melted and I had to splice in a new one.
- the black fuse holder pointing down to the left is a 4 amp fuse for the ammeter in the dash. The ammeter uses the wiring loom as an ammeter shunt, so there is one fuse on this side and one near the alternator. The ammeter measures the voltage at each fuse, and uses the voltage drop to estimate amperage flow.
- one of those other two wires off the junction point is a fusible link. According to my wiring diagram it should be in the charge wire from the alternator. It is an old style fusible wire where the fusible part is internal. If it starts to blow you will see the outside of the wire start to blister and bubble, and then finally burn. I made a mistake and hooked up my battery terminals backwards once, and it burned that fusible link.
The other wire on the junction is power from the starter lug, and it is a 10 gauge wire with a fusible link in the starter end.
You can buy fusible link wire at NAPA, but a better option is a pick and pull with a bunch of late era squarebody trucks and GMT400 trucks. GM started using links with a plastic barrel that is clearly marked (usually in millimeters), so the links are easy to see.
kevinc
arizona
kevin
great description. I was specifically looking for the fusible link to the horn relay and thought this link was spliced in the proximity of the junction block (i.e. spliced to red power line that goes from junction block, thru bulkhead connector and is then connected to horn relay).
hauto85
