Do I have a limited slip differential?
84K30
SWPA
Opened up the rear axle today for a fluid change and to confirm my axle ratio. Ring gear has 41 teeth & the pinion gear has 10. This matches my RPO codes on the sticker under the hood. My RPO codes also indicate that I have a locking differential but I don’t see the usual spring etc. that are in a limited slip diff.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Probably a Gov lock. The 14 bolt carriers are really hard to see inside.
nvrenuf
Mobile, Al.
Yes, that is a GM Gov Lock diff (RPO = G80). The 10.5" 14 bolt Gov Lock is identifiable by the 2 round cutouts that are close together (just to the right of the ring gear in the pic), this diff does not have visible springs for ID.
dvdswan
Port Orchard, WA
Dave
14 bolt FF (10 1/2" ring gear) the carrier splits in half to access the internals. 14 bolt SF (9 1/2" ring gear) is like most other carriers that you can see the spider gears and/or springs.
#18 is the carrier, 12-16 are the spiders and/or springs depending on the LSD or open carrier.
I guess we both learned something. I would have assumed it was open since the spring’s not right there like in the Corp 10 rear.
Hard
