Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
got a 1990 suburban, and i have a divorced np205 out of a international i was going to use on my big k5 build. decided on a 2.5 ton case, so the 205 is available for a 4x4 conversion. the suburban is 2wd, i want to buy a 1/2 ton set of axles for it, and convert it over to 4x4. i know i need to switch power steering boxes, do spring hangers and all. my question is, id like to just keep my 700 in the truck, and mounted up a divorced 205 behind it, seems like less work *to me*. im not a huge fan of transmission pulling and all being as i work alone, besides, im also not a huge fan of fiddling around with 700r4's anyways, not to mention the TV cable..... theyre finicky, and ive burned up 2 700's already, im scared to look at them, my feelings on a 700 is, if its not broken, dont fix it jackass! (talking to myself). I'd rather just leave it well enough alone instead of playing with fire.
so my question: i know that none of the chevy trucks ever came with divorce mounted cases, all married. but i ponder out loud, how much trouble would it be to fab up mounts and have a divorced case in the truck? other issue would be where the shifter lands, but with a little chop chop and weld splatter or a remote cable shifter, it could be in the factory position. i also know id need a front shaft, and the rear be shortened a bit. is this just over the top or does it even sound like a half decent idea? im not a "just buy something" kinda guy, im a DIY kinda guy, i want to convert it myself, instead of just buying a 4x4 burb.
looking for all input, good and bad, aint gonna hurt my feelings.
thanks guys
thanks guys
