Distributor, Plugs, Wires???
square_jimmy_83
West Columbia, South Carolina
Colby
Need help figuring out what i need to run for a distributor, plugs, and wires. im horrible with the search feature on forums.
Ive got a 1983 GMC Jimmy Sierra Classic w/ 350/th350. all factory engine at most will have voetec heads, cam, lifters, carb at later date. what would yall recommend that i run. truck will be used as a daily driver/ play toy.
as of right now its got the factory 83 distributor, autolite plugs, and i think oem delco wires. thanks for any and all help.
chengny
Let's see;
An "all factory engine" with:
Sounds fine just the way it is - let it run and save your money.
Don't get sucked in by all that aftermarket poser crap.
Georgeb
Wisconsin
George
K10 Burb Z71
Let's see;
I agree. Other than the plugs. I would run delco plugs instead of autolites in a gm engine. For some reason over the years it seemed that the Fords liked autolites, the chrystlers liked Champions and the GMs liked Delco. It seemed they would eat them up. It was a problem with my 71 dodge for sure. Only liked champion plugs. But I would run those plugs untill tune up time anyway.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Ac delco plugs, msd wires, msd distributor. Ditch the crap oem distributor completely.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
msd distributor, taylor plug wires, and delco or autolites for plugs
MikeB
Here's what I just ordered for my 350:
AC Delco 93440806
http://www.summitracing.com/parts/nal-93440806
Bought it at Amazon.com for $140-something. It even has GM's melonized gear for use with roller cams with steel gears.
IMO, this one is also a good choice:
Proform 141-682
http://www.summitracing.com/parts/pro-141-682/overview/year/1982/make/chevrolet/model/c10
As for spark plugs, what's important to me is heat range, electrode material, and physical size. I have had good success in Chevy small blocks with Champion, AC Delco, Autolite, NGK, and Bosch. I especially like the small (ISO-size) Bosch and NGK Platinum plugs for header tube clearance. For my current engine with Vortec heads, I'm using Autolite 605. Can't imagine I'll have any issues with them, assuming I selected the correct heat range.
I've always used MSD Helicore or Taylor SpiroPro wires, but this time I went with MSD Street Fire wires to save $20 or so. Never used an MSD product I didn't like, and that includes their Street Fire HEI distributor, BTW.
350runner
tx
Ceasar
I'm running moroso blue wires and a.c. delco plugs with a cheap dizzy
firebane
Calgary, AB
Curtis
Stock distributor is absolutely fine for most people. If you want to do anything to it then upgrade to a better coil or ignition module.
No point in blowing money on MSD stuff except their plug wires which are heavy duty.
MadOgre
NA
NA
NA
NA
NA
Exactly all you really need is a high energy coil and 8mm low resistance wires. What brand is up to you. If the stock distributor is in good shape?
Carb'ed Vortec 350
I just get Delco plugs and premium components from the parts store because by default they want to sell you the cheapest they have, so you have to request the premium cap, rotor, etc. It only costs a few extra dollars but you get a lot more bang for your buck. You can tell the premium stuff because they have brass inserts, not aluminum, and the color of the plastic is different too and you feel it is made better.
Joe383
Moses Lake
Joseph
I would just run stock replacement stuff. I have never noticed any difference in performance in expensive plugs and wires on a stock motor. Good plugs and wires might last a little longer though. What I have noticed that's worth it is a K&N air filter though or a knock off like it.
smoothandlow84
Steve
I use washable filters as well. Worth the $$ Imo...since the paper ones dirty up so fast here in the "dust belt state". X2 with using the heli power msd wires, especially with a higher than stock output coil. Oem will work fine as long as your coupling it with a stock distributor and coil. Higher power coils, distributors and wires all work better when used as a complete unit from my experience. Better fuel economy in most cases will be noticed, but that depends on driving habits. The power gains in my case where seen on the dyno.
square_jimmy_83
Colby
Thanks for all the replys. I ordered delco plugs, ICM, cap, and rotor button from work today. 68 bucks everything should be in tomorrow. Still have to order plugs. Can't decide between Moroso and MSD.
That Green Jimmy
Jleopard77
