Distributor install
Mango
JacksonWyoming
Gil
Installing a new distributor gasket will not seat all the way down marks i made all lined up! tried several times Think the oil pump drive is the issue? Use a long screw driver or turn the engine over by hand ??
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Screwdriver or tool of choice and keep trying it. Wiggle the rotor a little bit while trying.
fast 99
Spokane, Washington
Oil pump not line up. Either turn pump shaft with a long straight screwdriver or tap the engine over with key. When shaft lines up dist will drop.
Copymutt
Colorado
Take the helical dist. gear into account & start 20* counter clockwise. Should end up on #1 as it drops in.
If the distributor rotor is pointing where it belongs just like fast said. I just crank the engine while gently pressing on the distributor it will drop right in.
Mango
JacksonWyoming
Gil
Got the shop today and pulled the dist up aboit 1/4 inch and pushed down oh snap! Fell in place ??
All good runs great
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
All good runs great
Quite literally the way she goes.
Hard
