Disk brake conversion
chevydude
arizona
hunt
k20
Ok so I was looking at it so if i get the bracket does the roter just slide on to the axle housing
So how doese it work
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
You have to drive the lugnut studs out of the hub to get the drums off. Once the drums are off you put the rotors on in place of the drums and drive them back in. You will want to leave the lugnuts on the studs so you don't beat the threads up when you start trying to remove them, and an air chisel with the hammerhead attachment works great for this but I just used a 2# hammer and a steel drift. Your lugnut studs will end up being about 1/4" shorter afterwards because of the difference in thickness of the drum flange and the rotor flange but my lugnuts went on just fine, open acorn style holding on steel wheels. If you have aluminum wheels that the lugnuts recess into you may want to go get 1/2" longer studs. It took me about 3 hours to do this.
chevydude
arizona
hunt
k20
So can you explain how it goes on. does the roter just slide on how does it work.
nvrenuf
Mobile, Al.
Are you familiar with pulling the bearing hubs off of a front axle? It's the same type of set up.
chevydude
arizona
hunt
k20
sorry i didnt mean to post the second one i didnt thing the website put out my first post
Thanks for the info though
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i am doing it right now i got my axle stripped today an bolted the brackets on
i will get pictures and post them tommarow
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
does these pic cover your questions
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
MMMMMMM i wanna do this to mine when i do the new rear brakes instead of just putting new drums and shoes on.
So what do any of you intend to do for a parking brake or E brake?
crazy4offroad
Curt
K-10
350/SM465/NP205
Recently when using mine at the family cemetery, which has a VERY STEEP road going up, I just drove it into the ditch beside the road and let the hillside be the park brake. I know that isn't an option for some people and some situations, the ditch was pretty deep.
smurph20
Brad
Hydro lock like on a wrecker. Step on the brake using a manual valve lock out the rear brakes like a line lock on a drag car.
That's what I figured I'd use. Mico makes a kit. We installed on one of our tow trucks cuz it had one of those driveshaft drum brakes and wasn't holding very well. Fuggin bossman cut a 2x4 and used that on the seat to the brake pedal. I woudln't drive the POS and I told him about the Mico and he got it. No more excuses I had to drive it then. :rofl: Only a couple times though.
Mico Electric Brake Lock http://www.mico.com/products/brake-actuation/brake-locks/electric-activated-lock
Mico Lever Brake Lock http://www.mico.com/products/brake-actuation/brake-locks/lever-lock
chevydude
arizona
hunt
k20
Between the pics and your description i have it all figured out and completed the conversion thanks for all the tips.
aaron06
